CPU, Memory and Disk Space resource utilization
kaushalshriyan
Post by kaushalshriyan »
Hi Support Team,
I am using Nagios Core 4.4.5 on CentOS 7.7. I am monitoring 25 servers as of now. Is there a way to find out what is the current resource utilization of all the 25 servers. For example:- Server 1 -> CPU, Memory and Disk Space resource utilization and so on and so forth for the remaining servers. This is an exercise to do Capacity Planning in our Organisation to find out if the capability of current infrastructure (25 servers) is sufficient for the next 6 months to a year.
Thanks in Advance and I look forward to hearing from you.
Best Regards,
Kaushal
Re: CPU, Memory and Disk Space resource utilization
Post by Box293 »
Nagios XI comes with a lot of this built in as it comprises of a lot of different technologies.
Most likely you'll extrapolate that data from performance data. I would suggest you look at implementing Influxdb/Grafana. Here's some documentation on how to do that:
https://support.nagios.com/kb/article/n ... u-802.html
kaushalshriyan
Thanks Troy Lea for the reply. I will keep you posted as it progresses. Much appreciated for your help
cdienger
Post by cdienger »
Sounds good!
kaushalshriyan
Hi
Functionally it is working. I am attaching the screenshot. I am running
[img]
[/img]
Nagios Core 4.4.5
Last Modified: 2019-08-20
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 311 services.
Checked 34 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 28 contacts.
Checked 9 contact groups.
Checked 39 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 34 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Versions :- influxdb-1.7.9-1.x86_64 , grafana-6.5.3-1.x86_64, histou v0.4.3, Nagflux v0.4.1, CentOS Linux release 7.7.1908 (Core), Nagios Core 4.4.5
Please let me know if you need any additional information.
Best Regards,
Kaushal
kaushalshriyan
Hi Troy,
I see breaks in the graph as per the screenshot attached.
Best Regards,
Kaushal
kaushalshriyan
Hi Troy,
I am attaching the screenshot again for your reference.
Best Regards,
Kaushal
Post by Box293 »
The breaks in your performance data generally mean you are not receiving valid data back from the plugin during these intervals, or perhaps for some reason the performance data is being deleted before it is being processed.
You may want to look at the influxdb logs to see if it is reporting any errors.
kaushalshriyan
Hi Troy,
Please find the below details after investigating further.
[b]systemctl status nagflux.service[/b]
● nagflux.service - A connector which transforms performancedata from Nagios/Icinga(2)/Naemon to InfluxDB/Elasticsearch
   Loaded: loaded (/usr/lib/systemd/system/nagflux.service; enabled; vendor preset: disabled)
   Active: active (running) since Fri 2020-01-31 04:10:26 UTC; 12h ago
     Docs: https://github.com/Griesbacher/nagflux
 Main PID: 28895 (nagflux)
   CGroup: /system.slice/nagflux.service
           └─28895 /opt/nagflux/nagflux -configPath /opt/nagflux/config.gcfg
Jan 31 17:05:59 ip-172-31-0-145.ap-south-1.compute.internal nagflux[28895]: 2020-01-31 17:05:59 Critical: Connection type is unknown, options are: tcp, file. Input:
Jan 31 17:06:28 ip-172-31-0-145.ap-south-1.compute.internal nagflux[28895]: 2020-01-31 17:06:28 Critical: Connection type is unknown, options are: tcp, file. Input:
Jan 31 17:06:29 ip-172-31-0-145.ap-south-1.compute.internal nagflux[28895]: 2020-01-31 17:06:29 Critical: Connection type is unknown, options are: tcp, file. Input:
Jan 31 17:06:59 ip-172-31-0-145.ap-south-1.compute.internal nagflux[28895]: 2020-01-31 17:06:59 Critical: Connection type is unknown, options are: tcp, file. Input:
Jan 31 17:06:59 ip-172-31-0-145.ap-south-1.compute.internal nagflux[28895]: 2020-01-31 17:06:59 Critical: Connection type is unknown, options are: tcp, file. Input :
cat /opt/nagflux/config.gcfg
[main]
	NagiosSpoolfileFolder = "/usr/local/nagios/var/spool/nagfluxperfdata"
	NagiosSpoolfileWorker = 1
	InfluxWorker = 2
	MaxInfluxWorker = 5
	DumpFile = "nagflux.dump"
	NagfluxSpoolfileFolder = "/usr/local/nagios/var/nagflux"
	FieldSeparator = "&"
	BufferSize = 10000
	FileBufferSize = 65536
	DefaultTarget = "all"
[Log]
	LogFile = ""
	MinSeverity = "INFO"
[Livestatus]
#        # tcp or file
         Type = "file"
#        # tcp: 127.0.0.1:6557 or file /var/run/live
        file /usr/local/nagios/var/live.sock
#        #Address = "127.0.0.1:6557"
#        # The amount to minutes to wait for livestatus to come up, if set to 0 the detection is disabled
        MinutesToWait = 2
#        # Set the Version of Livestatus. Allowed are Nagios, Icinga2, Naemon.
#        # If left empty Nagflux will try to detect it on it's own, which will not always work.
       Version = ""
[InfluxDBGlobal]
	CreateDatabaseIfNotExists = true
	NastyString = ""
	NastyStringToReplace = ""
	HostcheckAlias = "hostcheck"
[InfluxDB "nagflux"]
	Enabled = true
	Version = 1.0
	Address = "http://127.0.0.1:8086"
	Arguments = "precision=ms&u=root&p=root&db=nagflux"
	StopPullingDataIfDown = true
[InfluxDB "fast"]
	Enabled = false
	Version = 1.0
	Arguments = "precision=ms&u=root&p=root&db=fast"
	StopPullingDataIfDown = false
Livestatus live socker file is /usr/local/nagios/var/live.sock
srw-rw----. 1 nagios nagios 0 Jan 29 07:20 /usr/local/nagios/var/live.sock
I have enabled the below in /opt/nagflux/config.gcfg. nagflux service does not start at all.
[Livestatus]
#        # tcp or file
        Type = "file"
        MinutesToWait = 2
        Version = ""
Nagios Cfg file
process_performance_data=1
host_perfdata_file=/usr/local/nagios/var/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
host_perfdata_file_processing_command=process-host-perfdata-file-nagflux
service_perfdata_file=/usr/local/nagios/var/host-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
service_perfdata_file_processing_command=process-service-perfdata-file-nagflux
#systemctl status nagflux.service
Active: failed (Result: start-limit) since Fri 2020-01-31 17:10:48 UTC; 3s ago
Process: 10845 ExecStart=/opt/nagflux/nagflux -configPath /opt/nagflux/config.gcfg (code=exited, status=2)
Main PID: 10845 (code=exited, status=2)
Jan 31 17:10:48 ip-172-31-0-145.ap-south-1.compute.internal nagflux[10845]: main.main()
Jan 31 17:10:48 ip-172-31-0-145.ap-south-1.compute.internal nagflux[10845]: /root/gorepo/src/github.com/griesbacher/nagflux/main.go:68 +0x22e
Jan 31 17:10:48 ip-172-31-0-145.ap-south-1.compute.internal systemd[1]: Unit nagflux.service entered failed state.
Jan 31 17:10:48 ip-172-31-0-145.ap-south-1.compute.internal systemd[1]: nagflux.service failed.
Jan 31 17:10:48 ip-172-31-0-145.ap-south-1.compute.internal systemd[1]: nagflux.service holdoff time over, scheduling restart.
Jan 31 17:10:48 ip-172-31-0-145.ap-south-1.compute.internal systemd[1]: Stopped A connector which transforms performancedata from Nagios/Icinga(2)/Naemon to InfluxDB/Elasticsearch.
Jan 31 17:10:48 ip-172-31-0-145.ap-south-1.compute.internal systemd[1]: start request repeated too quickly for nagflux.service
Jan 31 17:10:48 ip-172-31-0-145.ap-south-1.compute.internal systemd[1]: Failed to start A connector which transforms performancedata from Nagios/Icinga(2)/Naemon to InfluxDB/Elasticsearch.
Please suggest further and correct me if I am missing anything. I look forward to hearing from you. Thanks in Advance.
Best Regards,
Kaushal
kaushalshriyan
Hi Troy,
Checking in again if you had a chance to look at the post to this forum?
Best Regards,
Kaushal
