This is a cache of https://exchange.nagios.org/directory/Plugins/Databases/Oracle. It is a snapshot of the page at 2025-05-19T00:05:48.304+0000.
Oracle - Nagios Exchange
Search Exchange
Search All Sites
Nagios Live Webinars
Let our experts show you how Nagios can help your organization.
Contact Us
Phone: 1-888-NAGIOS-1
Email: sales@nagios.com
Login
Remember Me
Directory Tree
Category: Oracle
Nagios plugins for monitoring Oracle databases and database servers.
Nagios CSP
Meet The New Nagios Core Services Platform
Built on over 25 years of monitoring experience, the Nagios Core Services Platform provides insightful monitoring dashboards, time-saving monitoring wizards, and unmatched ease of use. Use it for free indefinitely.
Monitoring Made Magically Better
  • Nagios Core on Overdrive
  • Powerful Monitoring Dashboards
  • Time-Saving Configuration Wizards
  • Open Source Powered Monitoring On Steroids
  • And So Much More!
Submit Your Nagios Project!
Help build Nagios Exchange for yourself and the entire the Nagios Community by your Nagios project to the site. It's easy - just create an account, login, and add a new listing. Read the FAQ for instructions.
Category Listings:
There are 47 Listings in this Category.List your addon or plugin here!
ASP_NET_check_db_oracle
www.alan-pipitone.com
ASP_NET_check_db_oracle This plug-in allows you to check the connection from an IIS Web Server to an Oracle Data Base Server. It reads the connection string from the web.config of your Asp .NET applications, in this way if the connection string changes the plug-in uses the new ...
CHeck autoextend V2
check les DBF en autoextend
check DBF autoextended Oracle
check for dbf autoextended files or for dbf size in tablespace.
Check ORACLE CLUSTER "RAC"
This plugins verify oracle services (ASM,LISTENER,GSD,ONS,VIP) in "RAC" cluster, see config session on the script check_oracle_cluster.
Check Oracle status & health without install Oracle cli... Popular
This perl nagios plugin allow you to check oracle service (ability to connect to database ) and health of oracle databse (Dictionary Cache Hit Ratio,Library Cache Hit Ratio,DB Block Buffer Cache Hit Ratio,Latch Hit Ratio,Disk Sort Ratio,Rollback Segment W ...
This perl nagios plugin is a really enhanced version of the popular check_oracle_instant script. Latest updates see https://github.com/gdoornenbal/monitoring-plugins
LicenseGPL
When used through default configuration on 10g instances for example, the use of system account with DEFAULT profile configuration on the database runs the script to fail on the ORA specific error, generating an alert through NAGIOS that points to a "Cann ...
Check Remote Oracle through Ssh (No need to install Ora...
selectsysdatefromdual.gnusystems.net
New version 0.3 to fetch real undo usage ("UNEXPIRED SEGMENTS") (New version 0.2 with active sessions count, ASM diskgroups and hard/soft parsing percentage ratios check) This is the original official check_oracle nagios plugin, developed by latigid ...
LicenseGPL
Check tablespace usage and everything you can monitor b...
giuseppeturri.it/?page_id=9
Check tablespace usage and everything you can monitor by a SQL Query with Nagios Hi dear friends, here you can find a simple java code to check everything you can check through a simple SQL script / query without installing any type of oracle client or instant client: all that you need is nagios core 3.x and a Java JDK 1.6.0_xx versio ...
check_archiving for Oracle
Checks to ensure Oracle is in archive mode.
check_asm
Nagios plug-in for Oracle ASM instance (11g and above) It checks: a) disk status b) diskgroup state (mounted/dismounted) c) ASM alertlog for any ORA- errors occured in last 24 hours d) diskgroup used space; you can define warning/critical thresh ...
LicenseGPL
check_ASM_disk_groups
www.eldespistado.com
check_ASM_disk_groups Original Plugin “check_ASM_disk_groups” by Victor Ruiz with some improvements. New version v4. Added possibility to use Warning levels.
LicenseGPL
check_crs
Nagios plug-in for Oracle clusterware (11g and above) It checks: a) clusterware stack status b) OCR registry integrity c) Voting disks status d) resource status (ONLINE/OFFLINE); you can define exceptions with exclude option e) database instance sta ...
LicenseGPL
check_db
Remote oracle database check using JDBC drivers. Supports custom SQL queries and regular expression match. Provides similar funcationality as sitescope Db monitor.
check_dbversion_oracle
nagios.fm4dd.com/plugins/manual/check_dbversion_oracle.htm
check_dbversion_oracle This plugin tests the database software version through querying a specific Oracle database. It can either simply return the version string, or compare it against a blacklist/whitelist version file to determine software version compliance. because it exec ...
LicenseGPL
check_db_record
nagios plugin to check if a database record has been created today based on specific criteria (ksh script)
check_db_record_count
nagios plugin to check if a query returns a specific count based on a sql query within a specific timeframe (ksh script)
check_has
Nagios plug-in for Oracle High Availability Services OHAS (11g and above) It checks: a) ohas stack status b) OCR registry integrity c) resource status (ONLINE/OFFLINE); you can define exceptions with exclude option d) database instance status - if it ...
LicenseGPL
check_oracledb_replication
Command for checking the replication status of an AFCS file system. You can use this to check the status of you OracleDB replication.
LicenseGPL
check_oracle_asm_disk_groups
This plugin checks used space for oracle ASM disk groups against a threshold percentage provided in command line. User executing this perl script must have sysdba login privilege. Also in command line is necessary ASM ORACLE_HOME & SID
LicenseGPL
check_oracle_cachehitratio
Perl script for checking Oracle buffer cache hit ratio
check_oracle_health
labs.consol.de/nagios/check_oracle_health
check_oracle_health check_oracle_health is a plugin for the Nagios monitoring software that allows you to monitor various metrics of an Oracle database. It includes connection time, SGA data buffer hit ratio, SGA library cache hit ratio, SGA dictionary cache hit ratio, SGA s ...
check_oracle_objects
Perl script for checking the number of invalid objects in an Oracle database
check_oracle_tablespace
Nagios plugin to check Oracle tablespace usage
check_oracle_tablewrite
A plugin to check if it is possible to write to a specified table in an Oracle database instance.
check_oracle_tbs
Perl script for checking oracle tablespaces usage
check_oracle_v2
This check_oracle plugin is the same as check_oracle embbeded in Nagios Plugins Package (v1.4.14), BUT THIS ONE IS CAPPABLE TO MONITOR TEMP TABLESPACES TOO.
check_oracle_v3
www.klinikum-offenbach.de/
Extensions of standard plugin check_oracle: -Check of autoextend tablespaces by using the new Parameter --tablespace_AE added by Manfred Comes, mcomes@gmx.net -Check of temporary and permanent tablespaces (without regard of autoextension)by using par ...
check_orastby
Check the difference between active and standby oracle database
check_ora_db - full-featured plug-in for Oracle DB (inc...
Nagios plug-in for Oracle database (tested on 8i/9i/10g/11g). This script can be run remotely from separate monitoring host. It checks: a) database status (up/down) b) listener status c) session limit count d) alert.log errors within defined time ...
LicenseGPL
check_ora_rac
www.net17.de/
Check some Aspects of Oracle 10g RAC
check_rac
Nagios plug-in for Oracle rac (11g and above) This plugin is written with 2 main concerns: 1: works with Linux / Windows and regardless of the language (ENG / FR / etc.) 2: use exclusively the new crsctl command (11g-12c) and not the old deprecated ...
check_some_oracle_tablespaces
This plugin checks some tablespaces of a specific Oracle database.
LicenseGPL
check_sql_query
nagios plugin to execute a specific sql query (ksh script)
check_tablespace_oracle
nagios.fm4dd.com/plugins/manual/check_tablespace_oracle.htm
check_tablespace_oracle This plugin checks the tablespace size of a specific Oracle tablespace against WARN and CRIT thresholds. It returns the total tablespace size, current size, space utilisation in percent and the number of files belonging to this tablespace.
LicenseGPL
check_tablespace_oracle v1.2
Updated version of this excellent plugin, figured it would be of use to others: http://exchange.nagios.org/directory/Plugins/Databases/Oracle/check_tablespace_oracle/details Added check for Autoextension and Tablespace status. Displays MB inste ...
LicenseGPL
Nagios Plugin Siebel Remote
code.google.com/p/siebel-monitoring-tools/
This plug-in monitors if the Siebel Remote transactions pending to be routed to Siebel Clients number is lower or higher than the thresholds defined by command line options: depending on the values recovered, the output generated to Nagios will take care ...
LicenseGPL
Oracle Server Wizard
www.nagios.com/products/nagiosxi
Oracle Server Wizard Wizard for streamlining the monitoring of Oracle Servers that is designed to be used in conjunction with Nagios XI.
Oracle tablespace check
This is a tablespace-check for oracle databases. The check first gathers all tablespaces in an oracle database, then checks every tablespace against the given trigger-levels.
Oracle writeaccess
This plugin checks if it is possible to write to an Oracle database instance.
plugin to check oracle SID status
github.com/divyaimca/Nagios-Plugins/blob/master/check_orasid
plugin to check oracle SID status Plugin to check whether Oracle SID is up or down.
LicenseGPL
Plugins_Oracle
A plugin to analyse Tablespaces and HitRatio on oracle databases.
Script package for oracle
It's a script package for monitoring and graph database data in nagios and pnp4nagios or cacti. Maybe another exits before this, but here we make a perfdata usable for pnp4nagios, cacti and others similar graph tool. 1. Check_waits_cluster.sh and ch ...
LicenseGPL
yaonp - yet another oracle nagios plugin
yaonp - yet another oracle nagios plugin for a short overview a list of advantages and disadvantages for this plugin advantages - it works at least for my test enviroment consisting of Nagios XI (Linux, Ubuntu), Oracle 11g2 on Solaris 10 (Sparc) ...
LicenseGPL
