This support forum board is for support questions relating to
Nagios XI, our flagship commercial network monitoring solution.
cwscribner
Post
by cwscribner »
That brought the charts back
So it looks like now its set to 24h. Given the frequent usage indicated by the green and black lines, why are the last, avg, and max numbers so low?
Post
by scottwilkerson »
Yeah, I thought 24 hours was the default...
When you run the wizard it has a dropdown that asks you the speed you want to use, Gbps,Mbps,Kbps....
I believe the graphs use this value, however I don't know why you have a "m" on the left side to the graph...
Is this a low traffic interface or one that would be expected to average 20Mbps ?
I do know that this check by default uses the graph Template "check_xi_service_mrtgtraf.php"
cwscribner
Post
by cwscribner »
It would be expected to have numbers in the 20Mbps +/- range. The Xymon graph shows numbers in that range.
What should be my next steps?
I still need to
1) Fix whatever is going on with those numbers
2) Create a graph that will show a 30 minute window.
cwscribner
Post
by cwscribner »
My charts are back to not working at all. I tried re-uploading the perfdata component but that didn't fix it. Any thoughts?
Post
by scottwilkerson »
Are they totally blank?
Any relevant errors in?
# tail -f /var/log/httpd/error_log
cwscribner
Post
by cwscribner »
Totally blank. All are showing up as broken image links.
The apache log is filled with
sh: /usr/bin/rrdtool: No such file or directory
mguthrie
Post
by mguthrie »
cwscribner
Post
by cwscribner »
Interesting...rrdtool appears to be missing. It returned
Post
by scottwilkerson »
that's interesting, we are going to need that back
cwscribner
Post
by cwscribner »
Charts are back
They're missing a bunch of data though. Any way to remedy that?
