How histou passes result to Grafana
dhlao
Post by dhlao »
Histou has no problem passing the results that are returned by built-in check command. However, it fails if the result is returned by custom scripts. For example, command that is triggered by check_by_ssh.
I use check_by_ssh to get the CPU usage of a remote Linux server. It returns a text or numeric value, which I'm not sure its format; it represents the percentage of usage. Command as below
top -bn1 | grep 'Cpu(s)' | sed 's/.*, *\([0-9.]*\)%* id.*/\1/' | awk '{print 100 - \$1}'
Histou unable to plot a panel graph for this.
What I've noticed is that those results that can be plotted have status "OK" in their results, such as "OK", "PING OK", "DISK OK", and so on. I've no idea whether it's the cause or not.
