This is a cache of https://assets.nagios.com/downloads/nagioscore/docs/nagioscore/4/en/cgisecurity.html. It is a snapshot of the page at 2025-05-21T00:45:40.249+0000.
Enhanced CGI Security and Authentication · Nagios Core Documentation
Need Help Configuring Nagios?
Nagios XI Makes Monitoring Easier:
  • Web-Based Configuration provides advanced configuration features
  • Monitoring Wizards make it easy to monitor new devices, applications, and services
  • Customizable Dashboards allow for per-user customization
  • Integrated Performance graphs provide trending and capacity planning information
  • Advanced Reports provide data insight and exporting capabilities
  • Data Visualizations enable powerful analysis of patterns and problems
  • Nagios Core Import functionality makes it easy to migrate from Nagios Core
  • ... and many other features
Download a free 30-day trial to give Nagios XI a spin.
Up ToUp To: Contents
See Also See Also: Security Considerations, Configuration Overview
Security
Introduction
This is intended to be an introduction for implementation of stronger authentication and server security focused around the CGI web interface.
There are many ways to enhance the security of your monitoring server and Nagios environment. This should not be taken as the end all approach to security. Instead, think of it as an introduction to some of the techniques you can use to tighten the security of your system. As always, you should do your research and use the best techniques available. Treat your monitoring server as it were the most important server in your network and you shall be rewarded.
Additional Techniques
  • Stronger Authentication using Digest Authentication
    If you have followed the quickstart guides, chances are that you are using Apache's Basic Authentication. Basic Authentication will send your username and password in "clear text" with every http request. Consider using a more secure method of authentication such as Digest Authentication which creates a MD5 Hash of your username and password to send with each request.
  • Forcing TLS/SSL for all Web Communication
    Apache provides TLS/SSL through the mod_ssl module. TLS/SSL provides a secure tunnel between the client and server that prevents eavesdropping and tampering using strong publickey/privatekey cryptography.
  • Locking Down Apache Using Access Controls
    Consider locking down access to the Nagios box to your IP address, IP address range, or IP subnet. If you require access outside your network you could use VPN or SSH Tunnels. This is a easy and strong to limit access to HTTP/HTTPS on your system.
Implementing Digest Authentication
The implementation of Digest Authentication is simple. You will have to create the new type of password file using the 'htdigest' tool, then modify the Apache configuration for nagios (typically /etc/httpd/conf.d/nagios.conf).
Create a new passwords file using the 'htdigest' tool. The difference that you will notice if you are familiar with 'htpasswd' tools is the requirement to supply a 'realm' argument. Where 'realm' in this case refers to the value of the 'AuthName' directive in the Apache configuration.
htdigest -c /usr/local/nagios/etc/.digest_pw "Nagios Access" nagiosadmin
Next, edit the Apache configuration file for Nagios (typically /etc/httpd/conf.d/nagios.conf) using the following example.
## BEGIN APACHE CONFIG SNIPPET - NAGIOS.CONF
   Options ExecCGI
   AllowOverride None
   Order allow,deny
   Allow from all
   AuthType Digest
   AuthName "Nagios Access"
   AuthDigestFile /usr/local/nagios/etc/.digest_pw
   Require valid-user
</Directory>
Alias /nagios "/usr/local/nagios/share"
<Directory "/usr/local/nagios/share">
   Options None
   AllowOverride None
   Order allow,deny
   Allow from all
   AuthType Digest
   Require valid-user
</Directory>
## END APACHE CONFIG SNIPPETS
Then, restart the Apache service so the new settings can take effect.
/etc/init.d/httpd restart
Implementing Forced TLS/SSL
Make sure you've installed Apache and OpenSSL. By default you should have mod_ssl support if you are still having trouble you may find help reading Apache's TLS/SSL Encryption Documentation.
Next, verify that TLS/SSL support is working by visiting your Nagios Web Interface using HTTPS (https://your.domain/nagios). If it is working you can continue on to the next steps that will force using HTTPS and block all HTTP requests for the Nagios Web Interface. If you are having trouble visit Apache's TLS/SSL Encryption Documentation and Google for troubleshooting your specific Apache installation.
Next, edit the Apache configuration file for Nagios (typically /etc/httpd/conf.d/nagios.conf) by adding the 'SSLRequireSSL' directive to both the 'sbin' and 'share' directories.
   SSLRequireSSL
</Directory>
   SSLRequireSSL
</Directory>
Restart the Apache service so the new settings can take effect.
Implementing IP Subnet Lockdown
The following example will show how to lock down Nagios CGIs to a specific IP address, IP address range, or IP subnet using Apache's access controls.
Edit the Apache configuration file for Nagios (typically /etc/httpd/conf.d/nagios.conf) by using the 'Allow', 'Deny', and 'Order' directives using the following as an example.
   AllowOverride None
   Order deny,allow
   Deny from all
   Allow from 127.0.0.1 10.0.0.25       # Allow single IP addresses
   Allow from 10.0.0.0/255.255.255.0        # Allow network/netmask pair
   Allow from 10.0.0.0/24           # Allow network/nnn CIDR spec
</Directory>
   AllowOverride None
   Order deny,allow
   Deny from all
</Directory>
Important Notes
  • Digest Authentication sends data in the clear but not your username and password.
  • Digest Authentication is not as universally supported as Basic Authentication.
  • TLS/SSL has potential for "man-in-the-middle attacks". MITM attacks are vulnerable if an attacker is able to insert itself between the server and client such as in a Phishing attack, ISP monitoring, or corporate LAN firewall certificate resigning. So read up on certificate verification!
  • Apache access controls only protect the HTTP/HTTPS protocols. Look into IPtables for strong system wide firewall control.
  • Most importantly, Security is a moving target so stay informed and do research! Perhaps by listening to a Podcast such as "Security Now!".
