This is a cache of https://support.nagios.com/kb/article/installing-on-non-standard-systems-891.html. It is a snapshot of the page at 2025-05-14T00:46:57.919+0000.
Installing on Non-Standard Systems
Home » Categories » General Topics » Installation Guides
Nagios xi can be installed on several popular hosting platforms using existing Linux emulation and virtual machine software that is compatible with both Nagios xi supported Linux distributions and the host platforms.
Before beginning, ensure that you've looked through the supported system requirements for Nagios xi for help in configuring a VM image.
Microsoft Azure
You can create an Azure Virtual Machine to host your Nagios xi instance. Please see the following resources:
Linux Virtual Machines in Azure
Tutorial
After you have created and configured your Azure Virtual Machine, install Nagios xi using the instructions for the appropriate Linux distribution.
AWS
Amazon Web Services provides the ability to either launch a new pre-installed Nagios xi server in the Amazon EC2 cloud or to create a virtual machine from scratch and install Nagios xi. Please see the following resources:
Using Nagios xi in the Amazon EC2 Cloud
Launch a Linux Virtual Machine
If creating a new Virtual Machine, install Nagios xi using the instructions for the appropriate Linux distribution.
Google Cloud
You can also create a virtual machine with Compute Engine using the Google Cloud Console. Please see the following resources:
Quickstart using a Linux VM
After you have created and configured your Virtual Machine, install Nagios xi using the instructions for the appropriate Linux distribution.
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Installation Guides
Viewed 13741 times since Fri, Sep 13, 2019
How To Convert The Nagios OVA Virtual Machine For Other Hypervisors
Viewed 1992 times since Mon, Nov 18, 2024
