Nagios xi - How SNMP Traps Work
Viewed 6426 times since Mon, Nov 18, 2019
How SNMP Traps Work In Nagios xi Learn how SNMP traps work in Nagios xi so you can monitor your critical IT infrastructure! Final Thoughts For any support related questions please visit the Nagios Support Forums at: http://support.nagios... Read More
Nagios xi - Receiving IPv6 SNMP Traps
Viewed 9450 times since Thu, Apr 28, 2016
Overview This KB article explains how to configure Nagios xi to receive SNMP Traps that come in via IPv6 (Internet Protocol version 6). It is a requirement to have already followed this guide to install all the SNMP Trap pre-requisites:... Read More
Nagios xi - Receiving SNMP Traps From Nagios Network Analyzer
Viewed 7801 times since Mon, Oct 17, 2016
Overview This KB article explains how to configure Nagios xi to receive SNMP traps from Nagios Network Analyzer (NNA). It is assumed that Nagios xi is already configured to receive SNMP traps, if it is not please follow the steps in this... Read More
Nagios xi - SNMP Trap Hardening
Viewed 13004 times since Tue, Nov 6, 2018
Nagios xi - SNMP Trap Hardening This KB article explains how to harden your Nagios xi server to only accept SNMP traps from authorized sources. By default the Nagios xi server will accept inbound SNMP v2 traps from any device. SNMP v3 traps will not... Read More
Nagios xi - SNMP Trap v3 Configuration
Viewed 33628 times since Tue, Nov 13, 2018
Nagios xi - SNMP v3 Trap Configuration This KB article explains how to configure your Nagios xi server to accept SNMP v3 traps. By default the Nagios xi server will accept inbound SNMP v2 traps from any device. SNMP v3 traps will not be accepted by... Read More
Nagios xi - SNMP Traps with NXTI
Viewed 5526 times since Tue, Sep 18, 2018
SNMP Traps With NXTI This document describes how to use the Nagios xi SNMP Trap Interface (NXTI) to monitor and manage incoming SNMP Traps. NXTI was introduced with Nagios xi 5.5 and is enabled with the Enterprise edition license of Nagios xi.... Read More
Nagios xi - SNMPTT Service generates Cannot find module errors
Viewed 6699 times since Sun, Apr 9, 2017
Problem Description When starting or restarting the snmptt service you see output that looks like the following: Starting snmptt: add_mibdir: strings scanned in from /usr/share/snmp/mibs/.index are too large. count = 49 Cannot find module (SNMPv2-TC... Read More
Nagios xi - Update Default snmptt.conf EVENT
Viewed 9551 times since Mon, Nov 28, 2016
Problem Description After following the documentation to Integrate SNMP Traps with Nagios xi (https://support.nagios.com/kb/article.php?id=232) there are five EVENTs defined in the /etc/snmp/snmptt.conf file. These five entries have uncommented EXEC... Read More
SNMP Trap - Firewall Rules
Viewed 26155 times since Tue, Mar 24, 2015
Firewall Rules These steps explain how to check if the Operating System (OS) of the Nagios server has firewall rules enabled to allow inbound SNMP Trap UDP port 162 traffic. The different supported OS's have different firewall commands which are... Read More
SNMP Trap - How To Send A Test Trap
Viewed 231909 times since Fri, Apr 1, 2016
Overview This article shows you several methods of sending a trap to your Nagios server to test SNMP Trap functionality. Sometimes when troubleshooting an SNMP Trap issue, it can be very helpful to remove the actual device that could be causing... Read More
SNMP Trap - Inbound UDP Traffic
Viewed 27367 times since Tue, Mar 24, 2015
Inbound TCP Traffic These steps explain how to confirm that the Nagios server is receiving SNMP Trap traffic destined for it on the UDP port 162. In this example, the following applies: Remote computer sending SNMP Traps 10.25.5.20 Nagios server... Read More
SNMP Trap - snmptrapd Service
Viewed 72104 times since Tue, Mar 24, 2015
snmptrapd Service The snmptrapd service is what receives an SNMP Trap from the networking stack and then places it into a spool directory for the snmptt service to process. These steps help confirm that the snmptrapd service is working correctly.... Read More
SNMP Trap - snmptt Service
Viewed 45537 times since Tue, Mar 24, 2015
snmptt Service The snmptt service is what processes traps that have been placed into the spool directory by the snmptrapd service. "Processing Traps" means to look at the spooled trap and determine if it needs to be submitted to Nagios and how.... Read More
SNMP Traps - Nagios xi and NSTI - MIB Uploading
Viewed 7378 times since Tue, Apr 28, 2015
Nagios xi and NSTI Nagios SNMP Trap Interface (NSTI) is a stand alone product used for the searchability of trap tables, visualization of traps, and archiving of traps. It does not require a Nagios Core or Nagios xi implementation, it can e xist as a... Read More
SNMP Traps - Standard Handler vs Embedded Handler
Viewed 14675 times since Mon, Oct 24, 2016
Overview This KB article explains the differences between the Standard and Embedded handler for processing SNMP Traps. Detailed steps are provided to configure Nagios xi to use either method (the standard handler is the default used). Nagios xi 5.5... Read More
SNMP Traps - Understanding Trap Variables
Viewed 23402 times since Mon, Oct 24, 2016
Overview This KB article explains how to identify the SNMP Trap variables that e xist in traps and how they are used with SNMPTT. It is assumed that you have already configured Nagios xi to receive SNMP Traps by following this guide: How to Integrate... Read More
SNMP traps are now showing UNKNOWN for the sender IP
Viewed 4877 times since Tue, Jan 19, 2021
Issue: SNMP traps that had previously worked fine are now showing UNKNOWN for the sender IP. Solution: There is a bug (https://sourceforge.net/p/snmptt/bugs/46/) in version 1.4.2 of the snmptt daemon that your server is running which is causing it to... Read More
