Nagios xi and AD Authentication
This support forum board is for support questions relating to Nagios xi, our flagship commercial network monitoring solution.
adambot
Post by adambot »
Greetings,
I am having issues getting the AD integration to work with nagiosxi.
RHEL 5.7 64-bit, Manual install, SSL
I have tried creating users username and username@domain.fqdn.com with random passwords but neither works.
in the ssl_error_log i get the following:
[Wed Nov 23 10:06:41 2011] [error] [client 98.103.198.31] PHP Notice: Undefined variable: port in /usr/local/nagiosxi/html/includes/components/active_directory/active_directory.inc.php on line 252, referer: https://hostname/nagiosxi/admin/components.php
it also seems like i am missing some fields in the AD config screen (it doesn't allow me to specify bind dn or user)
thanks!
Adam
adambot
Re: Nagios xi and AD Authentication
Post by adambot »
i was able to make some progress with this.
for the user it should just be username without the account suffix
the problem was security -- the only thing available is SSL, and it seems to be broken? (when i turn ssl off, everything started working)
is there any way to get ssl to work?
thanks,
Adam
