Home »
Categories »
Multiple Categories |
Nagios xi - Mass Delete Old RRD Files |
Article Number: 854 | Rating: 1/5 from 1 votes | Last Updated by tlea on Tue, Sep 10, 2019 at 5:02 PM
This KB article will show you how to run a script to delete all RRDs (and their respective XML files) under /usr/local/nagios/share/perfdata that have not been written to in 5 days, that also includes hosts/services that have been DOWN for more than 5 days, please be aware of that limitation.
Steps
Establish a terminal session to your Nagios xi server as the root user.
Execute the following commands:
cd /tmp wget https://assets.nagios.com/downloads/nagiosxi/scripts/delete_old_rrds.sh sh delete_old_rrds.sh
You will be prompted to confirm that you want to proceed. Once you answer yes the script will output all the files it deletes onto the screen. If you are using an SSH terminal session through a program like Putty you may need to increase your output buffer to see all of the results as there may be a lot of output.
Final Thoughts
Have a question? Try our Forums! | Give Feedback |
1 (1)
Article Rating (1 Votes)
Rate this article
| Related Articles
Installing Nagios Mobile
Viewed 8470 times since Wed, Jan 27, 2016
SNMP Traps - Understanding Trap Variables
Viewed 23402 times since Mon, Oct 24, 2016
Nagios xi - Database Optimization
Viewed 7916 times since Thu, Jan 28, 2016
Nagios xi - SNMP Trap v3 Configuration
Viewed 33628 times since Tue, Nov 13, 2018
Nagios xi - Introduction to Event Handlers
Viewed 8893 times since Thu, Jan 28, 2016
