R20241.1.3 Multistacked graph Bug
paul_kessler
Post by paul_kessler »
I performed an upgrade to 2024R1.1.3 yesterday and I found that in the graph Explorer -> Multistacked graph you are unable to remove data types added to a graph. The default rta and pl counters cannot be removed along with anything else you add to the graph. If you hover over the X you get the rollover that says Remove from graph but it is not clickable. I validate that this was not caused by the upgrade I deployed a clean RHEL 8.9 instance and loaded R2024R1.1.3 from scratch and the same issue was present. I rolled back to 2024R1.1.2 and it works fine there.
cnorell
Developer
Re: R20241.1.3 Multistacked graph Bug
Post by cnorell »
paul_kessler,
For posterity's sake, what interface theme are you using? Presumably one of Modern or Neptune.
Regardless, I was able to reproduce the issue in Neptune, and will try Modern shortly. I'll file a ticket internally.
Thank you for the report!
Best Regards,
Cory Norell
paul_kessler
I tried in both Modern and Neptune. At first I thought it was just a problem with the theme so tried both.
swolf
Developer
Post by swolf »
Hi @paul_kessler,
This is a known issue; I'll make sure to increase the priority. Just so you're aware of our roadmap, we have another maintenance release (2024R1.1.4) coming out this week, which won't have the fix, but I'll see what I can do about getting this resolved for the next one. Just in case you want to check the changelog yourself without checking in with us, the tracking number for this bug is GL:XI#1135.
-Sebastian
Developer @ Nagios 2017-05-15 thru 2024-08-06
