Nagios xi errors [importnagiosql]
This support forum board is for support questions relating to Nagios xi, our flagship commercial network monitoring solution.
usanet_ops
Re: Nagios xi errors [importnagiosql]
Post by usanet_ops »
The service is working fine.
service httpd status
httpd (pid  16292) is running...
Here is the output from the E script. It does appear to be connection and running the wget without issue however does not seem to be retrieving the data.
Starting httpd:
/tmp/nagiosxi/nagiosxi/basedir/scripts /tmp/nagiosxi
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosql/index.php --no-check-certificate --post-data 'Submit=Login&tfUsername=nagiosxi&tfPassword=n@gweb' -O nagiosql.login--2011-01-21 17:50:16--  http://localhost/nagiosql/index.php
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:80... connected.
Length: 0 [text/html]
Saving to: `nagiosql.login'
    [ <=>        ] 0           --.-K/s   in 0s
2011-01-21 17:50:16 (0.00 B/s) - `nagiosql.login' saved [0/0]
IMPORTING CONFIG FILES...Array
    [0] => nagiosadmin.cfg
IMPORTING /usr/local/nagios/etc/import/nagiosadmin.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/nagiosadmin.cfg' -O nagiosql.import.monitoring
--2011-01-21 17:50:16--  http://localhost/nagiosql/admin/import.php
Saving to: `nagiosql.import.monitoring'
2011-01-21 17:50:16 (0.00 B/s) - `nagiosql.import.monitoring' saved [0/0]
SETUID ROOT OK
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosql/index.php --no-check-certificate --post-data 'Submit=Login&tfUsername=nagiosxi&tfPassword=n@gweb' -O nagiosql.login--2011-01-21 17:50:17--  http://localhost/nagiosql/index.php
2011-01-21 17:50:17 (0.00 B/s) - `nagiosql.login' saved [0/0]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --no-check-certificate --post-data 'writeMonitoring=Go' -O nagiosql.export.monitoring
--2011-01-21 17:50:17--  http://localhost/nagiosql/admin/verify.php
Saving to: `nagiosql.export.monitoring'
2011-01-21 17:50:17 (0.00 B/s) - `nagiosql.export.monitoring' saved [0/0]
Saving to: `nagiosql.export.additional'
2011-01-21 17:50:17 (0.00 B/s) - `nagiosql.export.additional' saved [0/0]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --no-check-certificate --post-data 'writeAdditional=Go' -O nagiosql.export.additional
OUTPUT:
Nagios Core 3.2.3
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 10-03-2010
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Error: Cannot open config file '/usr/local/nagios/etc/contacttemplates.cfg' for reading: No such file or directory
     directives and data defintions.  If you are upgrading from a previous
     may have been removed or modified in this version.  Make sure to read
RET: 254
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /tmp/nagiosxi/nagiosxi/basedir/scripts
tar: Removing leading `/' from member names
ls: /usr/local/nagiosxi/nom/checkpoints/nagioscore/*.gz: No such file or directory
NO NOM SNAPSHOT FOUND!
/tmp/nagiosxi
mguthrie
Post by mguthrie »
Hmm, I see that. Do you have any kind of special configurations on your machine that might prevent a wget request like that from going through? SSL? Special firewall rules? Proxies?
What happens when you try running one of those requests directory from the command line?
usanet_ops
Well, Looks like if I run the E script in /tmp/nagiosxi/nagiosxi/basedir/scripts the files exist.
-rw-r--r-- 1 root root 10518 Jan 24 21:21 nagiosql.login--2011-01-24
-rw-r--r-- 1 root root  5259 Jan 24 21:22 nagiosql.login
-rw-r--r-- 1 root root  5259 Jan 24 21:22 nagiosql.import.monitoring
-rw-r--r-- 1 root root   153 Jan 24 21:22 nagiosql.cookies
-rw-r--r-- 1 root root  5259 Jan 24 21:22 nagiosql.export.monitoring
-rw-r--r-- 1 root root  5259 Jan 24 21:22 nagiosql.export.additional
So appears the real issue here is where are the *cfg files in /usr/local/nagios/etc?
usanet_ops
I know you guys are very busy but I do want to get this evaluation version running as we are looking to purchase this product. Any help would be appreciated.
mguthrie
Post by mguthrie »
I think at this point your best bet to get this up and running quickly is to either start fresh with a clean install of either CentOS or RHEL (without gnome and registered with RHN), or a better and much quicker way would be to download our official CentOS VM with Nagiosxi pre-installed.
usanet_ops
I did ANOTHER fresh install this time and instead of downloading the standard xi I downloaded the Development version and guess what. It installed without issues. I must of installed the standard version 7 to 8 times with no luck. Anyway, long story short, I have xi up and running but with the development version of the software.
rdedon
Post by rdedon »
Glad to hear that there are no issues with this install. Do contact us again if you run into any problems.
Thanks!
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
