This is a cache of https://support.nagios.com/kb/article/nagios-xi-what-is-monitoring-xi-501.html. It is a snapshot of the page at 2025-05-16T00:42:10.980+0000.
Nagios <strong>xi</strong> - What Is Monitoring <strong>xi</strong> ?
Home » Categories » Products » Nagios xi » Documentation » Best Practices
Nagios xi - What Is Monitoring xi ?
Overview
This guide on Best Practices is about monitoring the Nagios xi server itself.
Probably the most important part of a monitoring system is knowing that it’s actually working. Nagios xi comes with a “Nagios xi Server” monitoring wizard to ensure everything is A-OK.
However there is no point in monitoring itself, if it’s down you’re not going to hear about it.
Utilize your DR instance to monitor the production instance. This way, if the production instance goes down, you’ll receive alerts about it.
The same applies for monitoring the DR instance, make sure production monitors the DR instance to make sure it’s healthy.
By using the “Nagios xi Server” wizard to monitor the other instance, you can have confidence knowing that when something goes wrong, you’ll really hear about it.
  • DR instance monitors production instance
    • Production instance is UP & HEALTHY
  • Production Instance monitors DR instance
    • DR instance is UP & HEALTHY
For information on your license entitlements, please refer to this KB article:
Documentation - Nagios xi - License Entitlements
Final Thoughts
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios xi - Service Dependencies
Viewed 11507 times since Tue, May 3, 2016
Nagios xi - MRTG Clean Configs
Viewed 8695 times since Tue, May 3, 2016
Nagios xi - xi Server Considerations
Viewed 7935 times since Mon, May 2, 2016
Nagios xi - Check Interval Considerations
Viewed 8155 times since Tue, May 3, 2016
Nagios xi - Macros and Custom Object Variables
Viewed 8218 times since Tue, May 3, 2016
Nagios xi - Configuration Wizards and Templates
Viewed 11483 times since Tue, May 3, 2016
Nagios xi - Best Practices for Managing Configs
Viewed 8927 times since Wed, Jul 19, 2017
Nagios xi - Groups
Viewed 10239 times since Tue, May 3, 2016
Nagios xi - Monitoring the Nagios xi "localhost"
Viewed 9072 times since Mon, May 2, 2016
