This is a cache of https://support.nagios.com/kb/article/nagios-xi-monitoring-the-nagios-xi-localhost-502.html. It is a snapshot of the page at 2025-05-16T00:42:12.023+0000.
Nagios <strong>xi</strong> - Monitoring the Nagios <strong>xi</strong> "localhost"
Home » Categories » Products » Nagios xi » Documentation » Best Practices
Nagios xi - Monitoring the Nagios xi "localhost"
Overview
This guide on Best Practices is about monitoring the Nagios xi server itself and what services you could deploy.
Do you know how your xi server is performing?
  • Services you should ideally be monitoring
    • crond, httpd, mysqld, ndo2db, npcd, ntpd, postgresql
      • postgresql is not used on fresh installations of xi 5.x onwards. If you upgraded to xi 5 from a previous version postgres is still used.
    • snmptrapd and snmptt are not present until you follow the xi SNMP Trap procedure
    • The plugin called check_init_service that is part of the linux-nrpe-agent.tar.gz package can be used to monitor these services
      • Requires the following line in /etc/sudoers
        • nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_init_service
      • Your command definition needs to be:
        • sudo $USER1$/check_init_service $ARG1$
  • File counts - check these folders to make sure the temp files are being processed
    • NPCD Perfdata spool directory
      • /usr/local/nagios/var/spool/perfdata/
    • xidpe spool directory
      • /usr/local/nagios/var/spool/xidpe/
    • Check results folder
      • /usr/local/nagios/var/spool/checkresults/
    • snmptt spool folderNOTE: These locations can vary if a RAM Disk has been implemented
      • /var/spool/snmptt/
    • Use the Folder Watch wizard to create services to monitor these folders
  • Has the nagios user account expired?
      • use lib ".";
    • To:
      • use lib "/usr/local/nagios/libexec";
  • root mailbox size
    • If you’re not a Linux person then you probably don’t know about the system mailbox. This is a local mail system on the linux server where messages are sometimes sent.
    • Certain components used in Nagios xi such as MRTG will send messages to this mailbox when it has a problem. An incorrect MRTG configuration can cause a message to be sent every five minutes as this is when MRTG runs. That’s about 288 messages a day. Over time the root mailbox can grow to GB in size causing issues. I wrote a plugin which can monitor this and let you know when it gets too big.
    • box293_check_mbox.plis the plugin you can use
    • File permission changes required:
      • setfacl -m u:nagios:r-- /var/spool/mail/root
  • Overall Load
    • This service is included by default in Nagios xi
    • check_load is the plugin included with Nagios xi (5)
  • Swap Usage
    • If the system runs out of physical memory and starts swapping to disk, the system performance will be greatly impacted.
    • check_swap is the plugin included with Nagios xi (5)
  • Disk Free
    • Disk free space is very important.
    • This service is included by default in Nagios xi however it only monitors /
    • If you have different volumes mounted then you should be monitoring each one of these.
    • check_disk is the plugin included with Nagios xi (5)
Final Thoughts
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios xi - Best Practices for Managing Configs
Viewed 8927 times since Wed, Jul 19, 2017
Nagios xi - MRTG Clean Configs
Viewed 8695 times since Tue, May 3, 2016
Nagios xi - Configuration Wizards and Templates
Viewed 11483 times since Tue, May 3, 2016
Nagios xi - xi Server Considerations
Viewed 7936 times since Mon, May 2, 2016
Nagios xi - Macros and Custom Object Variables
Viewed 8218 times since Tue, May 3, 2016
Nagios xi - What Is Monitoring xi ?
Viewed 4695 times since Mon, May 2, 2016
Nagios xi - Groups
Viewed 10240 times since Tue, May 3, 2016
Nagios xi - Check Interval Considerations
Viewed 8155 times since Tue, May 3, 2016
Nagios xi - Service Dependencies
Viewed 11508 times since Tue, May 3, 2016
