I have created one custom service now I need to show it under the report> Bandwidth Usage. kindly provide the steps to do the same.
Bandwidth report
Re: Bandwidth report
How are you doing?
I looked at my Nagios XI and it said you must use "Network Switch / Router Config Wizard" to use this report.
Best Regards,
Vinh
How are you doing?
Best Regards,
Vinh
I am fine thanks and how are you?
I need to show my service which is custom one not added from the nagios network wizard. IS it possible to show it under the bandwidth?
I'm good, thanks!!
Is your data a rrd files and resides under "/var/lib/mrtg" filder?
May I see your command used and the screenshot of your graph?
Best Regards,
Vinh
I'm good, thanks!!
Best Regards,
Vinh
Please find the below plugin which we used.
#!/bin/bash
text=`curl -s 'http://194.126.33.66/stat' | grep -A 2 '<name>12345</name>' | grep bw_in | cut -d'_' -f 2 `
bandwidth=`echo $text | tr -dc '0-9'`
if [[ $? -eq 0 ]]; then
echo "input bandwidth: $bandwidth bytes| bw=$bandwidth"
else
echo "input bandwidth: 0 | bw=0"
fi
#!/bin/bash
else
fi
Hope that your day is going well!! ...
Looks like your script does not generate the ".rrd" files that reside in the "/var/lib/mrtg" folder.
Sorry, but I don't think this will works in the Bandwidth report.
The requirement is that you must use the "Network Switch / Router Config Wizard".
Best Regards,
Vinh
Best Regards,
Vinh
