This is a cache of https://exchange.nagios.org/directory/Plugins/Hardware/Network-Gear/%2A-Generic/Uptime-of-router-or-switch/details. It is a snapshot of the page at 2025-05-18T00:27:56.521+0000.
Uptime of router or switch - Nagios Exchange
Home Directory Plugins Hardware Network Gear * Generic Uptime of router or switch
Search Exchange
Search All Sites
Nagios Live Webinars
Let our experts show you how Nagios can help your organization.
Contact Us
Phone: 1-888-NAGIOS-1
Email: sales@nagios.com
Login
Remember Me
Directory Tree
Rating
1 vote
Favoured:
0
Hits
107881
Files:
FileDescription
check_uptime.plUptime check
check_uptime.phpPNP Uptime Template
Nagios CSP
Meet The New Nagios Core Services Platform
Built on over 25 years of monitoring experience, the Nagios Core Services Platform provides insightful monitoring dashboards, time-saving monitoring wizards, and unmatched ease of use. Use it for free indefinitely.
Monitoring Made Magically Better
  • Nagios Core on Overdrive
  • Powerful Monitoring Dashboards
  • Time-Saving Configuration Wizards
  • Open Source Powered Monitoring On Steroids
  • And So Much More!
A Plugin to check the uptime of a router or switch With Perf out
Check of router or switch of uptime through SNMP using perl
input is entered in terms of
Usage: -H -C -p -w -c
There might be some errors at the moment but when i test it fully will update.
Checks uptime in minutes up if below a certain limit sets ouput as critical
You need Net::SNMP and Getopt::Long
ie Cpan
install Net::SNMP
install Getopt::Long
Also might need to change directory to /plugins/
service_description Uptime
use SERVICE_PRIORITY_TEMPLATE
host_name HOSTNAME
check_command check_cisco_uptime!Comm_string!warning!critical
command_name check_uptime
command_line /usr/bin/perl $USER1$/check_uptime.pl -H $HOSTADDRESS$ -C $ARG1$ -w $ARG2$ -c $ARG3$
::16/09/08 fixed wrong date time calc
::Added PNP graph template
:: 29/09 Fixed major error with format of time(reboot)
:: 23/10 Major remake fixed the time format finally yum out of beta am using it in production
::24/04/09 Fixed that annoying void error and added some basic help
