xi Traps ending up in snmpttunknown.log
This support forum board is for support questions relating to Nagios xi, our flagship commercial network monitoring solution.
Re: xi Traps ending up in snmpttunknown.log
Post by slansing »
Just want to be sure, is your issue resolved?
lapperb
Post by lapperb »
One more question...
Trying to view the State History reports, I can only see one of my hosts in the report. None of the other hosts return data when selected. Is there something I have to do to the host in order for its data to become available for reporting?
They will only show data if there have been a state change on one of the services in the time period selected.
So, if you have Last 24 hours selected but the other hosts do not have services that went down or came back up in the last 24 hours, they will not show anything...
lapperb
Post by lapperb »
Why would the SNMP traps not how up in the report for the host I am using to test? I select that host from the selection criteria and no data is returned.
You will need to make sure that the host is names the same as the sending item shows up in snmptt.log
This may be an IP address
lapperb
Post by lapperb »
Thanks again! I'll be starting the procurement process.
