Search Exchange
Search All Sites
Nagios Live Webinars
Let our experts show you how Nagios can help your organization.Login
Directory Tree
check_access_log.pl
Current Version
0.1
Last Release Date
2010-12-03
Compatible With
- Nagios 1.x
- Nagios 2.x
- Nagios 3.x
Owner
License
GPL
Hits
99892
Files:
File | Description |
check_access_log.pl | check_access_log.pl |
Meet The New Nagios Core Services Platform
Built on over 25 years of monitoring experience, the Nagios Core Services Platform provides insightful monitoring dashboards, time-saving monitoring wizards, and unmatched ease of use. Use it for free indefinitely.
Monitoring Made Magically Better
- Nagios Core on Overdrive
- Powerful Monitoring Dashboards
- Time-Saving Configuration Wizards
- Open Source Powered Monitoring On Steroids
- And So Much More!
Requires: nrpe, Nagios::Plugin, File::ReadBackwards, Date::Manip
Reviews (3)
bybelgotux, February 4, 2015
When you haven't any error in your apache log file, you've got this error :
Use of uninitialized value in addition (+) at ./check_access_log.pl line 152.
Illegal division by zero at ./check_access_log.pl line 152.
You can fix it with this diff :
diff /tmp/check_access_log.pl.ori /tmp/check_access_log.pl
152,153c152,156
if ( defined $status_score{'20X'} || defined $status_score{'30X'} ) {
> $failure_rate=
> sprintf("%0.2f", 100 - (($status_score{'20X'} + $status_score{'30X'})/$lines) * 100.0);
You also need that nagios can access to apache access file
152,153c152,156
> $failure_rate=
Is necessary install "File::ReadBackwards" and "Date::Manip" by cpan.
Excellent plugin, it does exactly what it states.
It comes also with a pnp4nagios template, available here:
http://blog.pburkholder.com/wp-content/uploads/2011/01/check_access_log.php_.txt
