check_xi_service_http does it load JavaScript from a page?
This support forum board is for support questions relating to Nagios xi, our flagship commercial network monitoring solution.
ecarrasq
Post by ecarrasq »
I'm doing a web page content check using the Nagiosxi Web Page Monitoring Wizard (check_xi_service_http)
The question was brought up,
"Does Nagios execute the javascript returned by these monitored pages?"
There are several JavaScripts that run when the page is loaded by a browser.
Eddie
Re: check_xi_service_http does it load JavaScript from a pag
this plugin does not execute the javascript.
For this type of check I would suggest
http://library.nagios.com/component/sea ... ord=autoit
or
http://library.nagios.com/library/produ ... -nagios-xi
ecarrasq
Post by ecarrasq »
Perfect! Thanks for the fast reply.
We actually are looking for Nagios to "Not" execute the JavaScript, so it worked out perfectly.
Thanks!
Eddie
Post by slansing »
Excellent, glad to see Scott's solution worked for you, have a happy holiday!
