19 Glossary Terms Found.
Nagios Exchange
Nagios Exchange is the central place where you’ll find all types of Nagios projects - plugins, addons, documentation, extensions, and more. Nagios Exchange is designed for the Nagios Community to share its Nagios creations.
Have a new project for Nagios that you’d like to share? Just create an account and add it to the directory.
Nagios Exchange
Nagios Fusion
Nagios Fusion is a powerful tool for visualizing operational status and enabling faster problem resolution across an organization’s entire IT infrastructure.
Nagios Fusion can connect to Nagios Core and Nagios xi servers giving a unified view across your entire infrastructure.
Nagios Incident Manager
Nagios Incident Manager is a powerful tool for managing infrastructure incidents and enabling faster problem resolution across an organization’s entire IT infrastructure.
Nagios Library
The Nagios Library serves as a central knowledge place for tutorials, videos, tech tips, downloads, and best practice information on all Nagios products and projects.
Nagios Library
Nagios Log Server
Nagios Log Server is a powerful enterprise-class log monitoring and management application that allows organizations to quickly and easily view, sort, and configure logs from any source on any given network. Log Server is designed to analyze, collect, and store log data based on custom specifications, and provide users with extended insight into the data on their network’s infrastructure.
Nagios Mobile
Nagios Mobile provides a flexible mobile interface for Nagios that works on iPhones, Android phones, and all other portable devices.
Nagios mobile comes pre-installed with Nagios xi and can be found on the xi server at the path:
/nagiosmobile/
Nagios Network Analyzer
Nagios Network Analyzer is a commercial-grade network flow data analysis solution that provides organizations with extended insight into their IT infrastructure and network traffic. Network Analyzer allows you to be proactive in resolving outages, abnormal behavior, and security threats before they affect critical business processes.
Nagios Reactor
Nagios Reactor is an advanced automation engine designed to save organizations time and money by reacting to problems without human interaction. Reactor allows organizations to rapidly develop, deploy, and manage complex automation tasks in and easy-to-understand manner.
NAT
NAT (Network Address Translation) is a method of using "private" IP addresses on home and office computer networks. NAT allows many computer systems to share a single "public" IP address. Monitoring remote devices/computers behind a NAT (e.g. on another network) can be challenging and may require port forwarding, a persistent VPN connection, or an agent like NCPA.
NCPA
NCPA is a cross-platform monitoring agent for Nagios Core and Nagios
xi that runs on Windows, Linux/Unix, and Mac OS/X machines. Its features include both active and passive checks, remote management, and a local monitoring interface. More information on NCPA can be found on
Nagios Exchange.
NDOUtils
NDOUtils is an addon for Nagios Core that allows you to export current and historical data from one or more Nagios Core instances to a MySQL database. NDOUtils is included with Nagios
xi. More information on NDOUtils can be found on
Nagios Exchange.
NetFlow
From Wikipedia: NetFlow is a feature that was introduced on Cisco routers that provides the ability to collect IP network traffic as it enters or exits an interface. By analyzing the data provided by NetFlow a network administrator can determine things such as the source and destination of traffic, class of service, and the causes of congestion.
Nagios Network Analyzer collects and analyzes NetFlow data to report bandwidth usage and traffic patterns in network activity.
NOC
NOC (Network Operations Center): In large companies or MSPs this is the main /central place where admins monitor the entire network. See also TAC.
NPCD
NPCD or Nagios-Perfdata-C-Daemon is part of an addon for Nagios called PNP4nagios.
The NPCP daemon is used to process performance data and place the performance data into RRD files.
Nagios xi utilizes the NPCD daemon to process performance data received by the Nagios Core engine.
NRDP
NRDP (Nagios Remote Data Processor) is PHP program designed to be a fle
xible data transport mechanism and processor for Nagios. It is most often used to submit passive checks to Nagios Core or Nagios
xi from a remote Linux or UNIX machine. It uses standard ports protocols (HTTP(S) and XML) and can be implemented as a replacement for NSCA.
NRDP is available from
Nagios Exchange.
NRDS
NRDS is a component pre-installed on a Nagios xi server that allows the administrator to create and manage configurations and plugins to be deployed with a passive agent that can be installed on a variety of operating systems including Windows, Linux, AIX & Solaris. The passive agents downloads the current configuration and the required plugin from the Nagios xi server and run the checks and posting the results to the xi server.
NRPE
NRPE (Nagios Remote Plugin Executor) is an addon allows you to remotely execute Nagios plugins on remote Linux/Unix machines. This allows you to monitor remote machine metrics (disk usage, CPU load, etc.). NRPE can also communicate with some Windows agent addons like NSClient++, so you can execute scripts and check metrics on remote Windows machines as well. More information on NRPE can be found on
Nagios Exchange.
NSCA
NSCA is an addon written in C that allows you to send passive check results to Nagios Core and Nagios
xi. The NSCA addon consists of a daemon that runs on the Nagios system and accepts passive checks from remote send_nsca client scripts. More information on NSCA can be found on
Nagios Exchange.
NSClient++
A Windows agent for Nagios that allows users to monitor metrics (disk, CPU. and memory usage), service states, and more using Nagios, xi supports the NSCIient++ addon and uses it to monitor Windows machines. Many users prefer NCPA over NSClient++ for monitoring Windows machines.
